short range non contact distance sensor
I need to measure the vibrations of the upper surface of a honey bee's thorax in order to trigger a video camera shutter and a flash in a strobe system. The oscillations are of the order of 200hz and have very low amplitude (I'll have to look it up but lets say ~0.1mm). The thorax is small so the measurement system must be focussed or something.
I've been looking at these:
www.keyence.co.uk/products/sensors/laser/lvh37/lvh37.php
I've not checked the prices but I'm guessing it may be costly, any suggestions, it can be analogue or digital, the propeller is sorting out the timing of flash and camera.
Cheers,
Graham
Cheers,
Graham
Graham
or should I say "Bzzzzzzzzz"
Don't you need a 3D measurement?
So you would need to measure some angles... right?
You could try using a progressive scan video on the long axes... and use a flash/pop to synchronize the video data (you would have to inject something into your analog stream at the same time of course). You could then get angular data by doing image processing on both video streams. (ImageJ again[noparse]:)[/noparse] Assuming that you have a one inch bee...you should be able to get about .04 mm resolution.
Rich
Lots-o-ideas,
Marty
Lunch cures all problems! have you had lunch?
It may be physically easier to manage that the phono cartridge. It is flat.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
