BS1USB Board with DS1620 Digital Thermometer
VonSzarvas
Hi all,
In the document for the DS1620 (www.parallax.com/dl/docs/prod/appkit/ds1620thermometer.pdf), it shows that 3 I/O pins are needed, and later mentions the BS1-IC giving plenty of program tips.
That all looks manageable! But my 3 questions are (before I order the relevant parts)....
1. Will the DS1620 work with the BS1USB?
2. As the BS1USB has 8 I/O's, and the DS1620 needs 3 I/O's, can I therefore add 2 DS1620 sensors to 1 BS1USB Board? (Leaving 2 spare digital I/O's, should I need to sense 2 switches or switch 2 leds off/on etc..!)
3. Is there a maximum recommended cable length between the bs1usb and the ds1620 sensors.. I am thinking of up to 10m...
... I think I have made an assumption that the usb board can power 2 ds1620's..... will need to check the specs...
Background: My idea is to have the device stream the temperature readings to a connected PC. Sampling speed is not critical - once every second would be cool, but even once a minute would be fine. (So once every X period, the board would perhaps send "T1,25,42" to the pc, where T1 means temp module 1, and the 2 temps follow.)
Thanks for your advice!
Max.
Max.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
That article (as you say) covers exactly what I was thinking.
I will experiment with 2 sensors and report back if the bs1usb can handle it!!
Also note the DS1620 is an SPI device. It can share its clock and data lines so 2 devices would take 4 I/O pins, and 3 devices would take 5 I/O pins, etc. Take care.
I am being lazy not looking as I type and think of this, but is there an SPI ADC chip/circuit somewhere that would plug so nicely as the ds1620 does?
http://www.parallax.com/detail.asp?product_id=ADC0831
