Reading analog voltage
How do i read a varying analog voltage (between 0-5V)? I'm sending the signal to PIN7, but all it's giving me is whether it's High (1) or Low (0). I need to read the actual voltage (e.g. 2.6, 3.8, etc)
Please help... this is urgent...
Vince
Vince
www.emesystems.com
You'll have to work your way down through some excellent BS2 tutorials. The particular use
discussed is as a battery voltage monitor.
same like Vince, I'm also looking for method to measure analogue voltage using RCTIME. From the tutorial, the voltage does not varies linearly with RCTIME. I need a method to measure the voltage linearly with Basic Stamp.
Tracy Allen
www.emesystems.com
