I think the A battery was for the filaments and the B battery was for the plate and maybe the screen as well. Does anyone remember what the other two filaments were for? I think one was for accelerating the electrons that got through the grid and the last one was for mopping up secondary emission electrons from the plate.
Mike Green said...
OK, I will now demonstrate to the world how old I am.
There were originally 3 batteries in the old battery operated radios (this is going back to the 1920's). The A battery, like you said, powered the filaments. The B battery supplied the plate and screen voltages (B++ and B+ respectively). There also was originally a C battery, which provided the negative bias voltage. However, it was discovered later that this voltage could be created by putting a resistor (optionally paralleled by a bypass condenser) in the cathode circuit, thus eliminating the C battery.
The first amplifying tube was the triode, which worked well at low frequencies, but at higher frequencies the plate-grid capacitance could cause oscillation due to positive feedback. Adding a second grid (the screen) between the control grid and the plate, and applying a voltage slightly below the plate voltage eliminated the capacitive coupling problem, but introduced a new one. When the electrons from the cathode struck the plate, they would knock a few electrons loose. On a triode these would just go back to the plate, but on a tetrode (aka screen grid tube) they would get attracted to the screen grid instead, a process called "secondary emission". The cure for this? Why add another grid of course, and call the new tube a pentode. This third grid, called the suppressor, went between the screen grid and the plate, and was usually (but not always) tied to the cathode. It's job was basically to chase the electrons back to the plate.
Well, this is probably way more than anyone wanted to know. But if folks are interested I would be happy to dicuss more of this old stuff.
While we're on the subject (sort of). Can sombody explain the difference between Vdd and Vcc. I know what they are, but the names seem to be used interchangeably. IS there a difference/distinction between the two?
Good read, Beanie2k! Yup, I remember using the old self-service "Tube Testers" at tha local electronics shop. see below
BTW - If you're looking for these, searching for "tube tester" won't work. You have to search for "VINTAGE Tube Tester"
Duffer said...
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
Dave Ratcliff· N6YEE
- Rick
VSS and VDD took alot of getting used to.
Brian
uController.com - home of SpinStudio
Negative and positive suggest 'relative to something else' ( an implied zero ), and in a two rail supply that doesn't really make much sense.
Notice that for PNP transistors Vcc was negative!!
That thing looks borderline steampunk.
There's nothing like a new idea and a warm soldering iron.
Post Edited (pwillard) : 8/21/2007 5:50:50 PM GMT
