You will have to De-solder and remove the exsiting board switch from the board and add two wires to the board where the NO pins were soldered to the board. You can re-use the switch that you removed from the board. Another choice would be to simply solder two wires to the board (bottom of board), at the exsiting NO switch pins, and attach another switch to the end of the wires that you just soldered on. Having two switches will be ok and you can use either one of the switches for a re-set....
Twisted Pair....
Post Edited (Twisted Pair) : 8/21/2007 12:02:11 AM GMT
Here's a circuit that will do what you want. It plugs into the BOE's DB9 serial connector. The switch is a SPDT push-button. When pressed, it connects +9V to the DTR pin (pin 4) of the DB9 plug, which resets the BASIC Stamp. When released, it grounds pin 4 to pin 5, discharging the DTR caps on the BOE, priming them for another reset. Be sure to use a switch that's rated "break-before-make" (most are), else you'll short your battery momentarily every time you push or release the button.
This will work, so long as you don't need the serial port for anything else.
Couldn't you just make a pushbutton the temporarily disconnects power from the board, thus resetting it? This would involve two 9V battery connectors and a normally closed button in between. If you arew running from a battery pack you could buy a 2.1mm jack and plug and wire the nc button in between.
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
END
Twisted Pair....
