T6963c anybody have code that works
been playing with a couple of 240 x 64 lcds either they are both bad or the code I have doesn't work. I have changed the code so many ways and so many times I'm definitely lost. I am using a BS2 on the homework board, but I do have a 9v power supply hooked up to it instead of the battery.
Does anybody have code that actually works?
and could you send it to me, pl pl pl plplease.
Post Edited (cyplesma) : 8/19/2007 11:46:36 PM GMT
- Stephen
here's the code, the latest that I tried, I have tried mixing the order of the pins that control the chip.
I haven't used any pull up resistors at all with the high imedance d0-d7 pins. On any device should pullup resistors be used?
I'll also include two of the many pdfs I have on this chip and one on the lcd itself.
- Stephen
I tried the b/w lcd with the stamp, seemed to get some weird stuff on the screen, thought I might have something going but alas, eventually I got a blank screen. Changed some code here and there, but nothing. Still, haven't given up.
but.... seems when I was doing this the voltage would change to a +3vdc while the power was applied to lcd. soooo I used a pot (correct thing to do anyway) to adjust the voltage to be -7 while the lcd was being powered.
the lcd does work with with lcdstudio. Just need to get back to wiring it up to the stamp and start my coding troubleshooting again. may not happen for a few days.
but if anyone else has code that works, I'll be happy to make use of it.
