Penguin spasms
Penguin went together okay and I did make sure that I centered the servos.· However, everytime I switch the power on, the servos twitch and hold to a new position.· If I repeat turning on and off the power, the servos will twitch further and futher until they·reach their end limits.
Is anyone else' penguin spasming like this?· I have other servo bots and some times the servos move immediately after the power is applied but if they do, they usually return to center position.·Also, I was wondering whether anyone has tried adding on a PING sensor.
Here's a nitpicky comment for Parallax's marketing department - penguins are native to Antartica.··If you are going to make a tie between the compass·and migration instinct it would be better to emphasize moving south instead of north.
2) Are your batteries ok?
3) Have you tried some of the test programs that come with it?
2. I have not metered the batteries but I have only used them for about an hour.
I have noticed that my penguin tends to waddle to the left. I have rechecked the lengths of my rods and they appear to be the correct length. When both servos are in the center position, should both feet be flat on the table?
The manual doesn't really describe what the gait mechanics of the penguin should look like. During stride, should only the lateral edge of the feet be in contact with the table and then the ankle rotate during mid-stride so that the foot is flat?
Post Edited (Grievousfish) : 8/19/2007 4:31:48 PM GMT
My Penguin tends to waddle in one direction too (also left). I haven't figured out why yet. When the servos are in center position, my Penguin is upright with both feet flat on the table.
My Penguin walks with the feet flat on the table. It leans to one side then the other as it walks in order to keep its weight over the "planted" foot as it moves the other foot forward.
mine had only one bolt a little to tight. now he walks strait.
scott
Mike - your penguin's feet stay flat during the entire stride? Hmm... I guess I should recheck the length of the rods because the only time my penguin's feet are flat are during mid-stride. The medial side of the foot is definitely raised during forward and rearward swing phases so that only the lateral edge is in contact with the table top.
BTW - I really do like my penguin! It is a great little bot.
Chris - will the wobbling of the PING sensor affect its operation? I was surprised how loose the fit is.
The important thing to remember is adjust the rubber band so the retaining pressure is exerted directly down on the Ping))) board into the socket. That prevents it from tilting and bending the socket.
humanoido
