Can't get host to see Javelin through USBtoSerial device
I can't get either my XP or my Vista machine to see my Javelin through the Parallax USBtoSER connector. The XP machine has a serial port that I can use to connect to the Javelin, so I verified that the Javelin is OK. Both the XP and Vista machines recognize the USBtoSER device and show USB Serial Converter listed under USB Serial Bus controllers in the Device Manager.
USB Serial port (COM6) appears under Serial Ports in the Device Manager on XP, but only COM1 and COM2 appears in the Identify list. When I plug the USB cord into either host, it assures me with a beep that the device is installed and I briefly see a flashing red LED on the USBtoSER, then the green LED stays on constantly. I have the problem with both a Javelin Demo board and a Super Carrier Board.
I installed the USBtoSER drivers from here:
http://www.parallax.com/html_pages/downloads/software/ftdi_drivers.asp
Any ideas?
Any ideas?
Select tab Debugger and click on button ...
to edit the port list. Add com6 to the list.
regards peter
need to be updated. Try the ftdi website to see if there are Vista drivers.
http://www.ftdichip.com/Drivers/VCP.htm
regards peter
Post Edited (Peter Verkaik) : 8/19/2007 1:06:32 AM GMT
http://forums.parallax.com/showthread.php?p=667184
It is about a basic stamp connection, but may apply to javelin as well.
regards peter
In any case, after running the executable, it still doesn't see the Javelin and no COM ports show up in the Device manager and I don't know what COM port to add. I added 1-11 with no luck. On my machine, there is no section called Ports in the Device Manager, and therefore no Serial ports are listed.
11. In the Device Manager, you should now have 2 New Entries: (1) under USB Controllers, "USB Serial Converter" and·*most important*(2) under Ports, "USB Serial Port (COMx)".· #2 is what will allow the Basic Stamp Software to "Identify" and "Connect" to the Basic Stamp.
You need to see the ports before the javelin can be identified.
The thread also tells not to run the executable. Use the zip.
regards peter
I can't follow the instructions in that thread exactly because I never get the request to install the driver but I will try to get it to work somehow. I need to figure out how to uninstall the one I already did install.
(God, I hate Vista! New laptop came with it and I have delayed the pain of going backwards (not) to XP till now, but think it might be time.)
11. Open the Device Manager. You should see a new entry with a Yellow exclamation!, that says "ft232r usb uart".
