Salvage with heat gun?
Oldbitcollector (Jeff)
I was doing some reading last night that a heat gun can be useful for salvage of electronics.
Since I just happened to have one, as well as some boards, I put the concept to work.
I'm curious.. Do components such as caps and SMD parts survive this process, or is it a waste of time?
Oldbitcollector
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Oldbitcollector
LCD displays and long connectors are also tricky - if overheated the glass can crack and the connector will melt.
You can shield these heat sensitive components with aluminum sheet stock or aluminum foil before using the heat gun on nearby components.
I have gotten into the habit of fluxing the parts before removal, as this seems to make the solder melt quickly and evenly, allowing me to remove parts quickly. Installing new parts with this station (using a fresh application of flux)·is a toss up: straight digital parts, like 74- series and comm chips like MAX232s, reinstall OK with this method. However, we use analog ADCs and MUXes, and these don't survive the process well. I end up wicking off the solder on the pads, applying flux and then hand soldering these parts back on.
The moral is: you can probably use your heat gun for sizable through hole and surface mount discrete parts, and maybe for most digital ICs, but if not sure, expect failure.
Yours,
kenjj
P.S the animated emoticons drive me nuts. Any way to stop these?
Most browsers will let you disable all GIF animations. Just check your "preferences" (or somesuch) menu item.
If they no longer work, you can always turn them into something like this, and probably sell them for 10x as much!
More here (and a howto).
Gr,
Mightor
| To know recursion, you must first know recursion.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 8/21/2007 12:34:28 AM GMT
