Toddler Servos Don't Run, But Hum
Hello,
I just received and built my new Toddler.· I performed the servo centering at times dictated by the instructions.· Now that it is all built, when I download and attempt to run the simple walking programs in Chapter 2, the servos do not move, but rather seem to hum.· I checked all the connections and loosened what some (in case they were too tight and straining the servos) but still have the same problem.
Any suggestions?· Is there any more information I can give to make this clearer?
Cheers,
Yes, a joint too tight would also cause this. I'm not sure about the Toddler, but perhaps having the left servo plugged into the right socket, and vice-versa, would also cause this?
