simple boe power question
D Faust
Can I input 6V to the 9V·battery connector for my boe (USB RevC)· I want to do thins becasue 9V battery clips are cheaper than 2.1 mm plugs, and with the plugs you have to get the inside and outside diameters right.· I just want a quick and easy method to apply power.· 9V battery connectors will connect to other 9V battery connectors right?· Thanks.
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum ON subnum GOTO Hope_this_helps, Thanks!, WOW!! END
Post Edited (Mike Green) : 8/18/2007 3:35:41 PM GMT
- Rick
I just thought of this:
RDL2004, if I just buy the plugs I have to get the polarity right anyway or I will fry my board.· (I wouldn't buy them pre-attached to a battery pack anyway)· But, I would still like the plug size/part number for future reference.
www.mouser.com/catalog/631/960.PDF
or just search: 2.1mm kobiconn plug -there are several varieties.
#1710-2110 will work
edit: you can get these from almost every electronics supplier, Mouser is just an example. Look for 2.1mm x 5.5mm.
- Rick
Post Edited (RDL2004) : 8/19/2007 2:22:57 PM GMT
Radio Shack part number, 274-1569. DC Power Plug, 5.5mm OD x 2.1mm ID, 2 pack....
Twisted Pair....
arranging the 5 Sub-C batteries into a pyramid (2 on top of 3), and running two wires from the end cells to
one of the Radioshack plugs mentioned above. For recharging, I simply clip a pair of alligator clips to the 9V sockets
on the Board Of Ed. (reverse polarity, + to the wide, - to the narrow, as if it were a regular battery plugged on.)
I can't seem to rind a source for it, but there was an old radio I had, which was a +6V 4-AA pack, but had a 9V connector
on the end.. (there is also a 6-cell version for full 9V)
IF you plan using the sockets for the 9V, You can wire a 9V wired cap to the 6V source, but (read this with CAUTION! )
run the wires from the cap to the supply reversed. (+ to - & - to +) Make sure you wire it correctly, or you
risk cooking the 7805 regulator. (the one on the board, and next to go will be the one on the BS2 itself! )
I've even made an adapter for the 7.5V NiMH RC Car battery for the old VEX, to the mini barrel connector.. (using the 9.6V RC
Car Battery repair kit Radioshack sells.) works just as well. same idea..
Hope this helps too!
Stephen
Whit+
- Rick
way back in the mid 80's I bought a wall wart, cracked the case, soldered an old ironing ac power cord (iron was dead, stripped it for parts like I do with most electronic stuff) to the wires that connected to the ac plugs on the case.
wired the dc output to a switch and then to a female RCA type connector (not really the best idea, but this was before the internet and before radio shack carried the dc plugs and jacks) I wired a male rc plug to a 9 vdc snap connector.
then glued the transformer laminates into a plastic box, oh yeah I even included a led (with resistor, but not on a pcb, heatshrink tubing). so I know when the dc out has power.
a safer thing to do would to put a 2d2p on off switch on the ac side, make sure you wire it so you use one ac wire to each pole on the switch, too make sure that if you have the switch in the off position you have both the neutral and the hot wires switched off.
don't want the hot wire to be connected when you accidentally leave it plugged in when you open the case.
