Propeller Internet Walkie Talkie
i think i have some kind of a "blackout"·now.
Maybe its just a stupid idea but is it possible building an Internet Walkie Talkie or an Internet-Speaker???
We have a propeller MIC and Audio Out and a running/working ENC28J60 Ethernet Chip.
Maybe just telefon quality will do it (up to 4khz).
I have received samples of the Dallas DS80C400 and they can do it !!!!!!!!
If Dallas can do it i think the Propeller can do it as well.
have fun
Franz
have fun
Franz
David
I would suggest starting out easy, such as using a dedicated mp3 decoder chip (STA013 or VS1011). The Propeller could connect to an online audio stream (usually mp3 streams) and feed that stream directly to the mp3 decoder chip. The Propeller would not be doing much, other than minor buffering and tcp connection handling.
Harrison
www.atcom.cn
I have a few of their AG-168V boxes. I think they cost something like $30 USD each. You just plug a phone into each box and make program them to address each other over the Internet. The nice thing about these boxes is that they come with the 8 kbps G829 codec, compressed RTP, and they do IAX, which traverses NAT/PAT by design and is fully compatible with the Asterisk free and open soft-switch (www.asterisk.org/). (You do NOT need a softswitch to act as gateway for the two boxes to connect directly). I just wish I could remember the name of the ASIC manufacturer for the part inside. It just seems like overkill to throw an 80 MIPs multi-processor part at something that's already done in a single low-cost ASIC. But then again the fun may be in the effort! Enjoy...
David
a lot of things are already done but ......
I was thinking about just using uncompressed audio, the same way they do it here:
http://www.maxim-ic.com/appnotes.cfm/an_pk/609
Maybe the MAX542 is not needed and the sample rate could be lower for telephone quality.
best regards
Franz
Graham
I think you should try it. Based on your success with the "New Propeller Board" you pulled together, I would expect you to pull it off nicely. Plus, my (selfish) reason for suggesting you do it is that you might post the method/code. This would enable others of us to learn and follow along.
Jim C
[noparse]:D[/noparse]
i think i will give it a try and start my first testings with UDP, when there is some spare time left.
As far as i can see, there is no special hardware needed, besides the ENC28J60 Ethernetchip.
have fun
Franz
@Graham: In the worst case (or the normal case?) this is not like havin gaps between letters, buthaving gaps within single letters
