DS1302 Sample Code
Here is a revised and simplified code for using the DS1302 with a Propeller.· The attached zip file contains all the objects used by the program.
The program assumes your VGA Start pin is 16, that your keyboard pins are 26 and 27, and that the DS1302 is plugged into Prop pins 2, 3 and 4.· If your setup differs from this, please make the necessary changes in the CON block.· The DS1302 operates at 3VDC.
All the information regarding functions, connections and operation of the program is contained in notes at the beginning of the program.· The program uses· Mike Green's OS system.
This program has been tested and works perfectly.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
