Prop Proto Board Servo Connections
I can't seem to determine if the servo connectors on the Prop Proto Board are connected to I/O pins or not. The schematic indicates they are connected to power and ground, but not signal.
Is this accurate?
Is this accurate?
Oldbit
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
