Considering writing a Prop Assembly debugger with breakpoints/single step. Has
I've been mulling it over and it seems very doable to create a mini-debugger for the prop that would allow a small bit of code (20-30 longs, added to an assembly module running in a cog) to support single step/breakpoints/debugging/disassembly of assembly code running in that cog. The debug "monitor" would communicate via shared memory with a serial communications engine running in another cog, and a Windows app would do all the real leg work of displaying the data.
Has anyone done this already for the Prop? I thought I had seen one go by but now I can find it. Perhaps I just remember reading about GEAR (which is a simulator, not a debugger). I didn't want to re-invent the wheel if it had already been done. I searched the forums and object exchange and couldn't find anything similar.
Paul Baker
Might this site refer to what you saw?
I'm presently running the single-cog (actually requires one more) 20 MHz sampling version of it to debug some assembly code.
Harley Shanko
h.a.s. designn
Without hardware support breakpoints have to be implemented by substituting instructions. This is a hard thing when having self modifying code
Good Luck!!
deSilva - Yes, you're right. Self modifying code would break an instruction-substitution breakpoint scheme. Without dedicated hardware debug hooks in the prop there's not much choice though [noparse];)[/noparse]
I haven't tried POD before. I'll give it a shot; at a glance it appears to do what I'm looking for.
Thanks everyone for the help.
Paul Baker
Paul Baker
But there is one pitfall: When illegally modifying the "next" instruction, it would work with the debugger, but not without
This is quite legal, and has no bad consequences at all
How large would that debugger become?
As you have to handle each instruction, even (and especially!) in "breakpoint" mode, there is no chance for real-time behaviour!
I've done such a debugger some month ago. It works exactly as epmoyer has described.
But I have no english documentation and I have not the time to make one (this is hard work for me).
So if someone is willing to translate a german site and add a little description of the menu and handling, and makes some demo-code, then I will send him the files and post it later in this forum.
The german version you can find here: www.insonix.ch/propeller/prop_pasd.html.
(the automatic translation by google is not totaly incomprehensible)
Some features:
- Allows realtime debugging on sourcecode level with labels !
- it needs a 12 longs wide debug kernel at the beginning of the code,
- a parallel running cog for communication with the PC,
- 2 shared longs at the end of the HubRAM for cog interaction.
- COM switching like PropTerminal.
Andy
I really like your debugger at first glance. I will give it a try later tonight when I get home.
POD is able to do single step debugging you was thinking. And of course it has an UI. Did you have never tried POD?
Thomas
@Ale: Can you give us same hints, as how to install your program?
Post Edited (deSilva) : 8/17/2007 2:01:19 PM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
sure,
get the latest version out of sourceforge
Unix instructions below (you downloaded it under /home/pacito/download) :
pacito@Maulotaur $ pwd
/home/pacito
pacito@Maulotaur $ mkdir usr
pacito@Maulotaur $ cd usr
/home/pacito/usr
pacito@Maulotaur $ unzip /home/pacito/download/pPropellerSim-0.6.zip
pacito@Maulotaur $ cd pPropellerSim
pacito@Maulotaur $ cd dist
/home/pacito/usr/pPropellerSim/dist
pacito@Maulotaur $ java -jar pPropellerSim.jar
enjoy
You can create a launcher under Xfce, Genome, KDE, etc, just type in the command field "java -jar <path/to/dist/>pPropellerSim.jar", without quotes, most of the times. Don't forget to have jre v1.5 (or jdk1.5), and java in your PATH.
pPropeller.zip
+ pPropellerSim
+ build
+ dist
+ doc
+ nbproject
+ src
+ test
Release notes are included in the file readme.txt in the directory pPropellerSim.
Sources can be erased, if not needed (just leave the /dist directory)
In the doc directory, instructions and a Changelog can be found.
Have fun
Ale
I'm sorry. I was referring to an instruction modifying the next one to be executed. Although it has defined results, it doesn't do what one might expect because the hardware has already fetched the instruction before the changed instruction is written. This would work differently on the debugger than with the real Propeller, but I would not complicate or slow down the debugger to implement this like the hardware. I'd simply document it as discouraged and likely to change with future hardware versions.
The case of an instruction modifying itself would be performed properly by the debugger as I've outlined it since the original instruction is modified properly.
Andy's (Ariba's) "PASD" tool is just fabulous! His tool even manages to parse the .SPIN file so that you can step you ASM code at the source level, and see the labels associated with cog RAM locations. I'm working to help him translate his documentation into English, so hopefully a public release will be forthcoming soon.
I go to the site and see:
Download: noch nicht m
Andy has not posted the download publicly yet. He wanted to get a good English translation of the documentation done before releasing. He sent me a pre-release so I could help translate the documentation and do some bug testing. The current release is very usable, and I wrote/translated about 1/3rd of the manual tonight, so a public release is probably not too far away.
