USB to 232 FTDI chip in DIP package
Does anyone here know of a FTDI IC packaged
in a DIP package (or a sub-assembly) ?
My eyesight is too poor to work with surface mount
Scott
Scott
It is not FTDI - it has a different type of chip and its own drivers, but it works well and is easy to add to a project. It uses .1 inch spaced headers to connect to your board, so you can either plug it in or solder it in, depending on your preference.· I've used these for about a year and they seem to work well.
It is possible to have an USB >>> serial device in a DIL Package.
http://www.obdev.at/products/avrusb/index-de.html
br
Franz
Cost is my biggest issue. I think I'm going to use the Parallax
2 transistor hookup and a cheap usb-232 molded cable.
I wish that ttl level usb cables did not cost $35 !
Thanks again
Scott
Maybe open the $10·adapter and "dremmel out" the MAX RS232·chip :-)))
br
Franz
propellerforum.sps-welt.de/viewtopic.php?t=83&postdays=0&postorder=asc&start=11
deSilva, I followed your link but did not find any photos. Where
should I be looking ?
To all: I did find one at Mouser for ~$20
http://www.mouser.com/search/ProductDetail.aspx?R=TTL-232R-3V3virtualkey62620000virtualkey626-DLP-TTL-232R-3V3
Manufacturer: DLP Design
Mouser Part #: 626-DLP-TTL-232R-3V3
Manufacturer Part #: TTL-232R-3V3
Franz
Oh, dear! I was not aware of that - that is chicanery!
Post Edited (deSilva) : 8/17/2007 5:57:03 PM GMT
Its a $10 Digitus DA70146 USB 2.0 zu Seriell-Adapter.
I can see a FT232BM + EEPROM + SP213 and there is a NPN Transitor :-)
This can be converted for the Prop.
Franz
Franz, if I understand this project www.obdev.at/products/avrusb/powerswitch-de.html this is just some AVR code easily portable to the Prop! So why bother with this interface rather than connect the USB directly?
Oh, I see - there is this stupid bootstrap loader
But I have just one PropPlug for all my Props (4? 5?) now, for downloading. I do not need it for the WORKING of them...
On the other hand, this is a $2 PropPlug - I am sure you can easily sell it for $ 20
Post Edited (deSilva) : 8/19/2007 9:40:45 AM GMT
i think the original question was "is there a USB chip available in DIP Package".
Of course there is no one available but making a $2 USB "PropPlug" by just using a ATTINY2313
is interresting.
Franz
deSilva, not today but what i can deliver is an one hour Digitus hack.
Just converted a USB2RS232 Converter to a "PropPlug" and it works.
This just saved me $40
have fun
Franz
and of course there is the parallax offering ....
www.parallax.com/detail.asp?product_id=28030
John Twomey
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 8/19/2007 1:44:15 PM GMT
·········· John Twomey
Post Edited (QuattroRS4) : 8/19/2007 1:49:07 PM GMT
here is my new stick,·i mean the·PropStick.
The hacked one running at a Parallax Proto Board.
edit:
Sorry, it should be PropPlug. Yes, i got it right now.
Franz
Post Edited (Franz Achatz) : 8/19/2007 6:28:26 PM GMT
Rgds,
John
better option. Thats for sure.
br
Franz
Rgds,
John
why do you use an RS232 device programming your Parallax Protos.
You can use your easyPROP too because there is a 4 Pin header onboard.
Just make a 4 wire cable from the easyPROP to the Parallax Proto Board and you can
load the Proto Board via the easyPROP's USB.
Only verify does not work.
br
Franz
and of course before I got the EasyProp !!
JT
My webcat-board can do the same but i only have one RS232 port available.
Its RS232 via Ethernet, right????
have fun
Franz
John T
Franz
·and a pic of loads more to do !!!
Post Edited (QuattroRS4) : 8/19/2007 7:09:28 PM GMT
But which one can handle it??
It will not be the easyPROP or Parallax Proto or Parallax Dev Kit but i think it will be
John's Industrial Control Board because you have a MAX232 onboard.
This Jocker goes to John !!!!!
Franz
