5-Cell "AA" holders — Parallax Forums
5-Cell "AA" holders
BeanBean Posts: 8,129
edited 2007-10-16 18:18 in General Discussion
Does anyone know where I can buy some 5-cell "AA" holders ?
I can't find them anywhere.
I know I could use a 1+4 or 2+3 but surely SOMEONE sells them in the USA.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 8/14/2007 12:47:27 PM GMT
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-08-14 12:47
    I've looked all over for these also, but I've never found any. You can get rechargeables in a 3x2 shrink wrapped pack, but no holders in that configuration. Best work around I've come up with is to use a 6 cell holder wilh one slot jumpered with a dummy cell and/or a wire.
    - Rick
  • Tim-MTim-M Posts: 522
    edited 2007-08-14 14:15
    I have used www.batteryholders.com in the past, but I don't see any 5-cell AA holders listed on their site.
    Tim
    edited 2007-08-14 14:25
    Although not ideal or the best use of space, how about using a 6-cell holder and wiring one 'slot' straight through?
    Just a thought,
    Tim
    edited 2007-08-14 18:27
    I have taken aluminum foil, folded it to ~ 1 inch longer than a AA cell, rolled it into a cylinder, compacted each end by banging it on a hard surface till it was the length of a AA cell and used it as a dummy cell.
    Paul Baker
  • David H.David H. Posts: 78
    edited 2007-08-14 19:34
    You should be able to take a 6 cell, and move the positive wire (or ground) to eliminate one cell.
    I was looking for one also for changing my Boe-Bot to rechargable. I ordered a 6 AA rechargable battery pack from Digi-Key. This will be 3 x 2 layers, and I'm planning on using velcro to attach it to the bottom. I'll see how this works.
    David
    There are 10 types of people in this world,...
    Those that understand binary numbers, and those that don't!!!
    Post Edited (David H.) : 8/15/2007 3:29:32 PM GMT
  • MightorMightor Posts: 338
    edited 2007-08-15 10:21
    I can't even find them at Farnell, which is pretty much one of the biggest electronics suppliers in Europe. You may need to hack your own. I doubt it'll be much of a challenge for someone such as yourself [noparse]:)[/noparse]
    Gr,
    Mightor
    | Any sufficiently advanced technology is indistinguishable from magic.
  • BeanBean Posts: 8,129
    edited 2007-08-15 11:38
    Okay that settles it...
    I'm going to find a source for these, buy a pile of them and sell them.
    It's the american way [noparse];)[/noparse]
    Bean.
    Teacher: Correct !
  • WhitWhit Posts: 4,191
    edited 2007-08-15 11:42
    Bean (Hitt Consulting) said...
    Bean.
    Sounds good to me!
    Edit - also saw this. We might make our own interchangeable 5 cell rechargable packs.
    http://mysite.wanadoo-members.co.uk/MaxxskunkworksU.K/the_5_cell_aa_battery_pack_mod.htm
    Whit+
    Post Edited (Whit) : 8/15/2007 11:48:48 AM GMT
    edited 2007-08-15 12:54
    Worst case, you could always buy clips like THESE
    Don't visit my new website...
    Post Edited (Gadgetman) : 8/15/2007 12:59:11 PM GMT
  • D FaustD Faust Posts: 608
    edited 2007-08-15 20:54
    Couldn't you remove the contacts from the 6th cell and use a wire to connect them. Lastly, you would cut off the part of the case with no contacts. What is wrong with a 4 cell and one cell wired together?
    LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
    LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
    ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
    END
  • pwillardpwillard Posts: 321
    edited 2007-08-15 21:03
    It's messy. Suppliers should know we need a 5-cell!
    There's nothing like a new idea and a warm soldering iron.
    edited 2007-08-15 22:27
    Has anyone contacted a supplier about this?
    FYI Radioshack sells battery packs for r/c cars that are 6V.(http://www.radioshack.com/product/index.jsp?productId=2103201&cp=2032056.2818124.2818347&parentPage=family)· I had two, but am not sure how to conect them to my bot.· Basically, there are two 5mm by 5mm plates, one on each side of the pack for the connection.· It is slightly smaller than a 5 cell pack (of AAs)·would be.· I hope this helps somebody.
    END
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2007-08-18 19:34
    Bean, where are these? Did you get us some?
    It's Only A Stupid Question If You Have Not Googled It First!!
  • WarholWarhol Posts: 1
    edited 2007-08-25 03:17
    Hi Bean,
    I found a 5 AA holder for sale in the UK...
    Here are the links:
    Catalog Page
    It looks like they cost ~7 Euros a piece though (about $10 US) so they're kind of pricey.
    Hope this helps...
    Jason
    edited 2007-08-25 06:13
    Perhaps these guys sell the battery related products you seek: www.onlybatterypacks.com.
    Gr,
    Mightor
    | To know recursion, you must first know recursion.
    edited 2007-10-01 02:16
    Okay, I finally found some.
    I had to purchase 300 pieces so these WILL be for sale.
    I should get them next week, so I'll post pictures and links to purchase them
    I'll keep you updated...
    Bean
    I know what I know, don't confuse me with the facts...
    edited 2007-10-02 00:58
    Bean
    I will buy some from you if the price is right
    Are they the type that you can put on a circuit boards or are they the type that have two wires and mount in a case
    Some times I·want to power my Basic Stamp on a Battery Back up but do not have a holder for them and do not want to have to put one together
    I have been watching this post to see what you come up with
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    edited 2007-10-02 02:23
    They are plastic with two mounting holes and 6" leads.
    I have to find out what the shipping charges are after I get them.
    The holders price hopefully will be $6.95 + shipping.
    Bean.
    Post Edited (Bean (Hitt Consulting)) : 10/2/2007 2:40:15 AM GMT
    edited 2007-10-02 02:26
    Thanks Bean
    That is great just what i have been looking for
    Sam
  • william chanwilliam chan Posts: 1,326
    edited 2007-10-02 14:29
    Why would anybody need 5 AA batteries?
    4 AA batteries would already give you 6V which you need to step down to 5V to run the SX.
    www.fd.com.my
    www.mercedes.com.my
    edited 2007-10-02 14:51
    So you can use NiMh batteries.
    They are only 1.2V per cell. So 5 cells gives the same voltage as 4 alkaline cells.
    Bean.
    edited 2007-10-03 21:41
    will parallax be offering these, or will i buy them from your website?
    edited 2007-10-06 00:07
    I just got the 5 "AA" holders today.
    They look nice.
    ·attachment.php?attachmentid=49742
    My goal is to live forever...Or die trying.
    Post Edited (Bean (Hitt Consulting)) : 10/6/2007 12:31:05 AM GMT
    537 x 321 - 43K
    539 x 470 - 53K
    edited 2007-10-06 00:12
    They do look good. I am going to try this and the BOE Boost and see which I like best. I figure there will be good uses for both. And the plan is?
    Whit+
    edited 2007-10-07 14:01
    How wide is it? Would it fit between the sides of the BoE-bot chassis?
    - Rick
    752 x 500 - 301K
    edited 2007-10-07 14:24
    Yes, it fits like a glove.
    Of course the mounting holes don't align [noparse]:([/noparse]
    Bean.
    768 x 576 - 74K
  • Paul Sr.Paul Sr. Posts: 435
    edited 2007-10-07 14:33
    Hey Bean,
    Are you going to be selling these?
    Paul
    edited 2007-10-07 14:51
    Paul,
    Yes, I need to find out what the shipping is from the post office tomorrow.
    Bean.
    edited 2007-10-07 14:54
    Bean said...
    That's what Velcro is for [noparse]:)[/noparse]
    - Rick
    edited 2007-10-07 23:39
    RDL2004, isn't the battery pack mounted 90 degrees from the way you have it. (I understand that Bean is trying to get the 5 to fit)
    END
