Illegal or undefined instructions
Hallo all,
The question is easy: What happens during the execution of an illegal (also known as undefined) instruction ? (assembler)
I did not test this, but I wanted to know the official statement
Some cases:
cmps y,x wr
cmpsx y,x wr
djnz a,#label nr
tjz a,#label wr
There are a coumple more, involving also HUB instructions.
Of course it can be tested in real hardware, but it does not mean that I will find out what exactly happens (may be they are ignored!)
All can be obtained with a long $<needed_value> so if the assembler ignores them and replaces them with a nop... they can still be generated!
Ale
Some cases:
cmps y,x wr
cmpsx y,x wr
djnz a,#label nr
tjz a,#label wr
Ale
My guess for "djnz a,#label nr" is that it loads a, subtracts one, sets/clears Z, then jumps if Z is clear. Because no result is written the register is left unchanged, it isn't actually decremented, making this a "Jump If Register Is Not Of Value One" instruction.
I'd guess that "tjnz a,#label wr" is the same as without the wr, but I guess it all depends on exactly what's in the 'holding bay' to be written when wr occurs.
With regard to cmps and cmpsx and subs and subsx, I would tend to agree, but they are different opcodes ! (110000 110001, 110101 110110). Regarding djnz I thought the same. It did not occured to me that maybe they can write once more what they calculated before... for instance in the case of tjz, nothing is _im principle_ calculated... mmm may be I can envision some testing code...
Note thet the effect of DJNZ is well explained in the manual: "DJNZ decrements the Value register and jumps to Address if the result is not zero. When the WZ effect is specified, the Z flag is set (1) if the decremented Value is zero. When the WC effect is specified, the C flag is set (1) if the decrement results in an underflow. The decremented result is written to Value unless the NR effect is specified."
