Multiprocessing with more than one Propeller
Hi again,
has everyone here in the forum build a system with more than one propeller chip, if yes is there a thread in this forum ?
Best whishes
Christopher
Best whishes
Christopher
Ale is right, here is the thread.
http://forums.parallax.com/forums/default.aspx?f=25&p=3&m=179824
Rob7
I have a board I designed with 3 Propellers on it ( I call it the TriMotor of course )
I needed most of one Prop for the user interface, Keyboard, mouse, VGA etc. the other two are set-up so I can use most of their I/O capability for machine control.
I have a 2 wire bus and a simple communication function I wrote that lets all three Props communicate with each other on-board.
It's been a nice controller for a new machine I developed.
KB
" Anything worth doing... is worth overdoing. "
··············································· ( R.A.H. )
A friend of mine used the following low cost solution: A standard 64/96-lines bus motherboard. Note the perfect spacing!
Post Edited (deSilva) : 8/14/2007 8:13:26 PM GMT
Sorry I'm so late in this thread...
Rob7 post the correct link...
I promised to post some spin code about it, but I still can't...I will soon (I hope).
It is about one propeller master, with 16 props as slaves.. in a paralell bus configuration.
Regards.
Alberto.
