I know that "repeat" and similar constructions are controlled by indenting the code that follows, but are commented-out lines part of that or are they ignored?
Basically, the indenting just looks at the starting column of the first "token" which should be some kind of identifier.
The column number is either the same or different. If different, it's either before (to the left) or after (to the right).
In the editor, try 'Ctrl I' to turn on the indentation highlights -- I leave in on all the time... This is one of the most useful and innovative feature I have ever seen in a structured programming editor...
I think SPIN is quite Python-esque in some of its syntax. The only thing I keep messing up is assignment. I am always forgetting the ":". I also always have the CTRL-I thing switched on, it helps when you have comments in between lines of code.
Gr,
Mightor
| Any sufficiently advanced technology is indistinguishable from magic.
Gr,
Mightor
