Servo question
I am using the BS2 to control a set of servos, but the movement jerks too much. I am using the PULSOUT command similar to:
Start:
·· PULSOUT 0, 190·· PAUSE 20GOTO StartIt either moves too fast (smooth) or when I increase the PAUSE command it (jerks) to the next position. Is there a way to smoothly control a servo at slow speed? I am using a push button like control, not a pot. THANKS!
Start:
goal var word ' desired pulse width srvP var word ' actual pulse width start: srvp = 750 goal = 750 cycle: ' calculate a new goal if srvp < goal then if goal - srvp > 10 then srvp = srvp + 10 else srvp = goal endif endif if srvp > goal then if srvp - goal > 10 then srvp = srvp - 10 else srvp = goal endif endif pulsout 0,srvp pause 20 goto cycle
