Any suggestions on reverse engineering a circuit board
![Capt. Quirk](https://forums.parallax.com/uploads/userpics/9JPOS4RYYPQ0/nAZVBWA800QOI.jpg)
I have an ignition system board from a company that I worked for from 90 to 94, at which time it went out of business. I have been working on maping it out, off and on for about a year now. And the longer I work on it, the more I have learned about electronics and that board. There is no real control to it, other than the hall effect sensor & reluctor and a set of 555's that control the DC to DC converter. There is also no ignition curve, except for what happens as a result of the rpm increasing and time decreasing. Eventually I want to control it with an SX and finally a Propeller after I know how to fit the micro controllers in.
So, does anybody know if people do this (reverse engineer a circuit board), or is there anybody here that does it. And how much do things like this cost? The board is about the size of a PC-104 format and I have pictures of both sides and maps that I have been·working on in·Photoshop (besides the board itself).
Bill
Bill
(did anyone say 'Easy target for lawsuit'? )
Don't visit my new website...
(Just kidding)
There's nothing like a new idea and a warm soldering iron.
What I don't understand is the how & why (The basics)·of automotive protection circuits.
Does anybody have an idea about what it would cost to bring my own circuit to an Electronic Engineer and have him/her add the Automotive protections my project would require. (or possibly suggest a book)
Bill
I heard that they did take him to court over it and got him to dismiss the design as a copyright infringement.
Anyway all I used was a meter to check for traces on the board. I tried to first draw out on paper·the parts placement on the board and then draw connection points as best as I could. Start with the Vcc and Ground connections and then move on to the more difficult ones.
I never got a perfect drawing but had enough information to go to court with.
Good luck.
By coloring the back of the board traces one color and the front traces another color when you merge them you can see all the traces. Assuming of course it is a double side board without internal layers.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
- Stephen
I do want to learn from the board,·why these circuits have been designed with high ohm resitors (pull downs I think) and capacitors to protect it, and·what made·it·reliable product. I have bought several books, but I haven't discovered any info to help.
Thanks for the response,
Bill
Quality and Reliability are not.·It was a quality product that would meet or exceed your expectations, even as it was becoming obsolete.
(I'm just an electronic hobbiest that want to learn the·how and why, of quality and reliability, to the best of my ability)
Bill
·If anybody wants to be a mentor for a 47 yr old kid, that looks like Shreck.
Send me a PM
Post Edited (Capt. Quirk) : 8/15/2007 5:27:14 PM GMT
