PSC and CMUCam Troubles
Hi everybody,
I built a robot with with a bs2sx and boe.· Currently, I have a a Ping sensor, PSC, Solarbotics motorcontroller, serial LCD, CMUcam app mod, PSC and PIR sensor connected to my robot.· I have the Ping sensor mounted to a servo and I also have a claw driven by a servo which· are both connected to the PSC.· I made a object avoiding program that worked pretty well using the Ping sensor and the homemade turret that it is mounted on.· I have also made programs for the CMUcam using the demo code that I got offline.· However, if I have the·CMUcam connected to the BOE at the same time as the PSC, the PSC will cease to function after a couple of seconds or not function at all.··Sometimes the green light will flash on the PSC, but it is obviously not working because I can't hear the servos being held at their neutral position.· I am almost positive that this·is a hardaware·issue because the PSC will power on for a piece of code that it will not power on for,·once the CMUcam is connected.· Maybe its because of the way the appmod is hooked up to the boe?· Anyhow, I am really frustrated with the situation and·I am hesitant to plug my servos directly into my boe because they will not have a seperate power source like they do with the PSC and I am getting a lot of flutter/lack of precision control.· I can't position the servos as well as I do with the PSC.· PLEASE HELP ME SOMEBODY!
Thanks for your help.
thanks for your reply. At this time I do not have a way to measure the average and peak current loads of each device, but it sounds like you are on to something; I hear that the CMUcam draws a lot of power.. The CMUcam, lcd, Ping sensor, PIR sensor are all run off of the regulated power of the BOE. The PSC is also plugged into x3 slot 13, however, it is powered by a 6 cell nicad battery that also powers the motor controller. Even if the PSC and the CMUcam are the only things plugged in, they do not function properly together. I have a 9v 300ma power supply that I bought from Parallax for my BOE and the regulator only gets slightly warm.
