Running on 3 rechargeables
Hey Guys,
I know the datasheet says 3.6 is within the range the propeller is good for, I'm just wanting to know if any kind of hickup will cause failure at that voltage (like getting a transient on TTL being run at 5.5 V and having catastrophic failure). Otherwise I'm going to throw a diode in there and run on 2.9 V.
I would avoid the series diode and simply use some form of shunt regulation which would clamp the supply. When the batteries are freshly charged their unloaded terminal voltage can be around 20% or so higher than normal so the shunt regulator quickly brings the batteries back to "normal" [noparse]:)[/noparse]
*Peter*
NiMH/NiCads wll run the prop down to 1.1volts/cell maybe even 1.0V each if you underclock the prop at 3.0volts.
Better solution is a single Lithium Ion/polymer, charged they are 4.2V and nearly flat at 3.3V.
Worried about batery life, add switchmode reg.
Gavin
(1) 3 NiCd cells (600mAh) in a small and very low cost "pack", in series with a 4001 diode. As I recharge often, the voltage at the batteries is generally around 4 V (starts with 4.2)
(2) 4 NiMH AA cells (2600mAh) which have become astonishingly low cost for some time! I reduce to 3.3 V with a LOD regulator. The main reason for this is that I need an exact voltage for the delta sigma circuit, and I use some devices that will run better "around 5 V" which are fed directly by the - somewhat random, but unrippled - raw batterie voltage.
http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?family=analog&familyId=661&uiTemplateId=NODE_STRY_PGE_T
They are relatively cheap at 1 to 3 €
This is not advertisement. National has also many, and Freescale also.
