how much voltage does the bs2 put out?
when the command
High1
is executed, how much voltage does the stamp put out? I need to use the stamp to put out 5v. If that doesn't do it what will?
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
High1
HIGH pin will send out 5 volts dc.
LOW pin will give 0 volts dc.
Using a HIGH 1 command will provide 5 volts DC output on·pin P1·(which is actually pin·6 on the BS2). You should probably set a value to "1" (as it is misleading what pin you are sugesting).
Pins P0 - P15 on the BS2 (actual pins 5-20) are either configured as Input pins or output pins.
As the BS2 Help example states:
' HIGH_LOW.BS2' This simple program sets I/O pin 0 high for 1/2 second and low for' 1/2 second in an endless loop. Connect an LED to P0 for a simple' blinker.' {$STAMP BS2}Main: HIGH 0 PAUSE 500 LOW 0 PAUSE 500 GOTO Main ENDMake sure you realize how "long" you want the 5 volts dc output voltage to be sent out of the pin.
Once you do this you should be able to switch the volt ohm meter·to VDC and touch the 2 leads (black and red) together and it should get close to 0 or 0.00 something.
At this point you should be able to measure 5volts dc between actual·pins 6 (for I/O pin P1 - use red lead) and Vss ground (actual pin 4 - use black lead).
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
