Formatting SD card to F16 for use with the Prop Chip
··· I am starting to build the SD R/W card setup to use with the Propeller Proto/Demo boards.
· I used Windows XP SP2 admin tools/computer management/disk management to format the
· SD card which is mounted on a USB SanDisk Mobilemate SD+ reader unit for FAT16 filesystem.
··· I am using a 512 MB NVC SD card with the breakout board from Spark Fun Electronics.
··· The format function only allows FAT or FAT32 for the Filesystem choice, selecting a large
· cluster size makes no difference.
··· Is there another way to get a FAT16 filesystem to format on the SD card? or will the card
· work in FAT with the Prop.
········ Thanks in advance.
FORMAT X: /fs:fat /a:8192
(Replace X: with whatever your drive is)
Oldbitcollector
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
format x: /fs:fat /a:32K
for all cards larger than 256MB. Larger sectors (32K) means fewer metadata writes
and more sequential reads/writes (essentially, more speed).
· If I type·format E:/fs:fat16/a:32k·· where E: is the SD card, the Command prompt says:
· Format not available for FAT16 drives
· If I type format E:/fs:fat/a:32k, The SD card is formatted as FAT which I assume won't
· work with the SD SPIN code
· What now?
FAT is a generic term for FAT12, FAT16, and FAT32, where the number 12, 16, or 32 denotes the
number of bits used to number clusters. When you tell format to use /FAT, it looks at the
/a option and the size of the volume to determine the number of clusters, and then uses
whichever of FAT12, FAT16, and FAT32 is appropriate. (I think.)
Either of the two commands provided by us should work without problem. Have you tried?
panasonic.jp/support/global/cs/sd/download/sd_formatter.html
I use it all the time.
*Peter*
I had the same questions and troubles when I breadboarded my spark fun SD card reader.
I found that with windows XP, The selection format fat works, though it formats the SD card in fat16.
You can check it, by downloading the format utility swissknife V3. Just do a goggle search . The download and the utility is free.
Rob7
Fat 32 is not supported by the propeller.
Some links that may help .
·http://tomas.rokicki.com/fat16work/
·http://forums.parallax.com/showthread.php?p=658173
·http://ucontroller.com/propellercookbook.pdf
Enjoy,
Rob7
Post Edited (Rob7) : 8/11/2007 4:45:54 AM GMT
