overclocking a propeller chip
what is the highest speed, which can a propeller chip be driven without problems.
I tested it with 20Mhz and PLL=8x without problems, but what is recommended.
The chip will not warm up.
Best regards
Christopher
Best regards
Christopher
I'd also like to know the answer to this, as it'll be interesting [noparse]:)[/noparse]
I read a while back about using a 6Mhz and PLL=16x to 96Mhz, and other talk about taking it up to 128Mhz, no worries.
But 20Mhz at PLL8x that would be good. how long did you test it for? how many hours? constant usage? was it doing LOTS at that speed? like a tv driver, and graphics examples, with all cogs running full whack?
I'm curious, as this is double the current speed of 80Mhz, and would theoretically double how much a scanline renderer could do [noparse]:)[/noparse]
Cheers,
Baggers.
did you measure how fast the chip was ACTUALLY running? There was an older thread on over-clocking that had lots of info. (well worth digging up) If I remember right 128MHz is the fastest the PLL is specified to run. (10MHz crystal and 8x works, so i guess it will keep a lock at 160MHz) Also from that thread, stuff like the zero flag and cary flag start failing at over 100MHz. Most likely you had the PLL running at it's top speed, and then were using 1/2 that as the system clock. (likely in the 90-100MHz range)
heh, If you want the chip to warm up, Paul (i think) posted a demo that caused the Prop to draw 1.7 watts or something. Basically he setup the counters on all the cogs to toggle all the pins as fast as they could.
Later,
Marty
Lunch cures all problems! have you had lunch?
I share Marty's skeptism of being able to run the chip at 20MHz x 8PLL. Neither the PLL was designed to run·at 320MHz (remember that regardless of what tap you choose, the PLL is always scaling it up by a factor of 16), nor was the Propeller designed to run at 160MHz.
Paul Baker
In fact the FTDI propstick type DIP board is designed to run at that speed.
I must admit that I haven't tried going any higher but why would you want to?
is 160Mips not enough these days? lol
Just waitfor PROP II.....
Coley
After all, this IS the land of big-block Chevys...
Nice thought though.
Baggers.
The aerosol cooled chip wasn't that much faster.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/10/2007 7:42:33 PM GMT
Baggers, i'm guessing you tried setting to _xtal2 or 3?
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Paul Baker
Paul Baker
That's amazing !
I remember way back when I used to overclock the Rendition graphics card's.
Great info for maybe some overclocking projects in the future.
Rob 7
And after you're done testing, toss it in pan of water and have a prom.
