simple clock project
everyone bear with me because im kinda new to this stuff...i want to build a device that controls a seven segment LED clock display, specifically a SLED-4C from rentron.com if any of you are familiar.· i want to program the display to run thru a custom "message" as soon as it is triggered with a contact closure from a show control unit.· any help is appreciated. thanks
If you'll want to build a compact device on your own board later, get a Stamp and the Board of Education (Serial or USB). If you want something cheaper to learn with, get a Basic Stamp Activity Kit which you can get from Parallax or Radio Shack. That's designed to run off a 9V battery. You'll need a USB to serial adapter if your PC only has USB. I recommend Parallax's or one from FTDI or Keyspan's High Speed adapter. Others may or may not work for programming the Stamp.
