Proto Board/Win ME/Hyperterminal
I have the Proto Board working well and talking to Hyper at my desk using XP and the Prop Plug..··I would like to move the setup to my workbench, which has a computer with WinME·and use Hyper there since there is no spare VGA on the workbench.· Do I need to install some kind of an FTDI program or a USB serial converter so I can use the Prop Plug with ME?· There will be no programming - all I want is one-way communication from the Proto Board to Hyper via the Prop Plug.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Parallax USB2SER Development Tool
compatible with ME?· Does one end plug into the Proto Board and the other into a USB port.· Would I need any drivers or is it self-contained?
Sid
Don't have VGA?
Newzed@aol.com
The signals at the miniD connector however have the wrong polarity, thus you have to add one of the many (I count three itn he meantime) circuit suggestions for the different Propeller boards. As you want to send only, you will need one direction only (1 transistor, 2 resistors)
But as you can configure most Propeller drivers for inverted polarity, you might not even need this, as USB-to-serial converters live easily with 3.3 V.
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Any other suggestions?
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
I tried averything again today on the ME.· After I booted up, I plugged in the Prop Plug - Windows ignored it, which tells me it recognized it.· However, when I tried to open my Hyper file·for the Proto Board, it said "Cannot open Com4"· Tried Com 1, 2 and 3 with same result.· The Proto Board, with the LCD was running and continued to run during all my efforts.
Sid
Don't have VGA?
Newzed@aol.com
WinME was known as a particularly unstable OS. Everyone I know who had it cursed it on a daily basis. Is there any reason (other than cost) for not upgrading to WinXP?
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/14/2007 10:48:03 PM GMT
Sid
Don't have VGA?
Newzed@aol.com
