It should also be mentioned that you can log data on the Stamp itself, quite a bit of it if you have the BS2pe with its extra memory slots. To offload the data you can use the serial port to a PC running Hyperterminal or one of the products from Selmaware.
The advantage of the external cards is that you can store a lot, lot more data, and you can carry the card to your PC reader and retrieve the file very fast and effortlessly. I like Bean's SD datalogger because of its easy one wire serin/serout connection to the Stamp, and its streamlined instruction set. I haven't tried the FTDI/Parallax interface, but it appears to have a more flexible interface and more capabilities, at the expense of complexity
(i.e., learning curve).
And I sell the SD Data Logger http://www.hittconsulting.com/products/sddatalogger/
I would suggest you read over the manuals and see which one best fits your application.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
I do not have the Parallax part. I do have Bean's machine. It works very well indeed, as I am sure the Parallax part does.
I will probably get the Parallax device as well.
--Bill
You are what you write.
Tracy Allen
www.emesystems.com
