i need help in this!!!!!!! — Parallax Forums
ardilloardillo Posts: 4
edited 2007-08-08 10:20 in Propeller 1
hi!!!! i have problems with this program:
*** when method init_standby called method armed, an then i try to exit armed i have to strike input 1 twice or maintain pushed for about .5 secs,output 7 gives a little 2 pulses(dont want it!!!). i·supposed to only·need one pulse for exit armed
*** i want that init_standby do not execute if input 3 == 1.execute if input 3 == 0
i try to add another pub but it dos'nt work
········ HHHHHHHEeeeEEEEEELLLLLLLPPPPPPPPPP!!!!!!!
var
· long stack [noparse][[/noparse]12]···· 'stack space for cognew instruction
· Pub init_standby |· Lock
pin 0 = activation
pin 1 =· deactivation
pin 2 = monitors the status of sensors
pin 3 =·machine is on·}}
· dira [noparse][[/noparse]0..2]~· 'sets pin 0-2 as inputs
· repeat··································· 'loops for always cheking below lines
··· Lock· := ina[noparse][[/noparse]0]·················· 'takes the value of input pin 0
··· if· Lock == 1···················· 'condition for the calling of armed sub routine
····· cognew (flasher,@ stack)· 'a new cog executes sub_routine
····· armed································· 'sub_routine
····· if armed == 1
······· cogstop (1)
pub armed | Unlock,Lock············ 'sub_routine armed
· dira [noparse][[/noparse]6..8]~~······················ 'sets pin 16-18 as output
· !outa [noparse][[/noparse]7]··························· 'raise pulse for locked doors
· waitcnt(6_000_000 + cnt)
· !outa [noparse][[/noparse]7]····················· 'the drop pulse for locked
· repeat
··· !outa [noparse][[/noparse]6]
··· repeat
······ Unlock· := ina [noparse][[/noparse]1]
····· if· Unlock· == 1
······· !outa [noparse][[/noparse]7]
······· return 1
pub flasher : index· | pin· ' {declaration of the the sub_routine led_Flasher
······························· 'returning its value trought "index"}.{"Pin" is a local variable.}···············································································································································································································································
· dira [noparse][[/noparse]16..23]~~
··· repeat {1}··················· 'Endlessly loop···············································································································································
{repeat {2} is used to turns leds on from left to right}
····· repeat{2} index from 1 to 7 'will execute until "index" reach 7, when exit repeat {2} automaticlly "index" return to 0
······· pin := index + 16········ 'indicates which led in the corresponding demo_board pin turns on
······· !outa [noparse][[/noparse]pin]·············· 'toggles pin output
······· waitcnt(2_500_000 + cnt)· 'delay time
······· !outa [noparse][[/noparse]pin]·············· 'toggles pin output again
{repeat {3} is used to turns leds on from right to left}
····· repeat{3} index from 1 to 7 'as "index" loose its value from repeat {2},will execute until "index" reach 7
······· pin := 23 - index········ 'indicates which led in the corresponding demo_board pin turns on
······· !outa [noparse][[/noparse]pin]············· 'toggles pin output
    edited 2007-08-08 08:08
    can you attach it in a file, the indentation has been changed I think
    Graham
  • KaioKaio Posts: 287
    edited 2007-08-08 09:49
    ardillo,
    you are calling the subroutine armed twice. One time without checking result and one in the if statement. You should it only call in the if statement.
    Thomas
    well spotted you can just have
    armed
    cogstop(1)
    because armed will never return unless the button is pressed.
