Sensirion Temperature/Humidity Sensor
Hello all,
I have recently purchased the Sensirion Temp and Humidity Sensor from Parallax for a Weather Station project I am starting.
Does anyone have a recommendation for an appropriate enclosure/radiation shield for this unit?
I'm looking for something I can build myself for $10-$20.
www.weather-watch.com/smf/index.php/board,54.0.html
Check the topics on "radiation shields" and the thread on the home-made weather station that was in Nuts and Volts Magazine.
- Rick
- Stephen
There are a couple of things to keep in mind. One of the most important is to have a double or triple ceiling over the sensor. The purpose of that is to lessen the heat load from the sun above. Also, there is generally a double plate on the bottom to reduce heat load from below, and that is important if the device is to be installed over a hard surface that will get hot, as opposed to a surface like lawn. Ventilation from the sides and a surface coating that reflects well in both the visible and infrared is also important. The plates should not be deep so as to trap the rising hot air, and the hot air has to have an escape path above the level of the sensor itself. In general, larger is better. A location in the shade of a tree or bush or arbor is better than nothing and is often better than a shelter. In testing shelters having identical exposure and placement, the one reading the lowest temperature is considered the best.
Another issue is protection from contamination. That is a consideration in agricultural fields. Sprays like sulfur are deadly for these sensors, and an agricultural fogger is very effective at delivering spray to every nook and cranny. Another difficult situation is near or on the ocean.
Tracy Allen
www.emesystems.com
Do you think it is a wise idea to paint the sensor with a silicon conformal coating to prevent oxidization? Is it too risky as one may get the conformal in the humidity sensor port?
What have others done? Toss it under a radiation shield and call it good?
The Parallax version is a SHT11 chip mounted on a dip carrier with a pullup resistors for the data line. Be sure you add the suggested pulldown resistor for the clock line and a capacitor across the power close to the chip. You'll probably need a good socket for it. It could probably last a long time without a conformal coating, but if you do apply it, obviously be very careful not to get any of the stuff into the sensor opening.
Tracy Allen
www.emesystems.com
I see a trip to the home improvement store in my near future!
- Stephen
Keep it up off the ground and out of the shade....basically in an area without obstructions for a few meters around it!
I wouldn't put a vent fan in there or anything (not unless you are measuring dry and wet bulb temperatures to determine a calculated Relative humidity)
And in this case there are distinct calculations for a motorized vent and a non-motorized (and also for elevations).
There's been a bit of discussion about the type of material the shield should be made of.
Plastic, engineered wood (that recycled wood/plastic stuff)....types of paints....vinyl/latex...etc...
Anyhow, if you aren't looking for accuracy to a tenth of a degree, don't worry about material (well, metal is an obvious no!)
So long as you are up off the ground and not in the middle of a concrete parking lot, you'll probably be alright!
cheers
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
