waitcnt — Parallax Forums
waitcnt
NewzedNewzed Posts: 2,503
edited 2007-08-12 22:44 in Propeller 1
Can the Propeller execute more than one waitcnt, where waitcnt follows waitcnt?· I had an event occurring every 30 seconds and I wanted to increase it to 60 seconds.· I added another waitcnt line the same as the first but the delay stayed at 30 seconds.· Do the waitcnt's have to be separated by another instruction?
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
«13
    edited 2007-08-07 15:15
    WAITCNT is not really a delay instruction. It's a "wait until this time comes" instruction. You do delays by calculating a time in the future, then waiting for that. That's why you see a lot of "clkfreq/1000 + cnt". The "clkfreq/1000" tells how many clock cycles it takes to do 1/1000 of a second. The "+ cnt" adds the current time to get a time in the future (1ms in the future in this case).
  • KaioKaio Posts: 277
    edited 2007-08-07 15:48
    Sid,
    I don't know how your statement looks like but it should work with more than one waitcnt. Please be aware that the maximum time can be 53 seconds with one waitcnt statement.
    Thomas
  • NewzedNewzed Posts: 2,503
    edited 2007-08-07 16:33
    Thanks, Mike and Kaio.· I can get a 59 second or 61 second wait.· Going to add .25 secs to 59 second wait and see what happens.
    Sid
    Don't have VGA?
    Newzed@aol.com
  • deSilvadeSilva Posts: 2,967
    edited 2007-08-07 16:42
    edited 2007-08-07 17:01
    Sid,
    You can't get more than about 53 seconds' delay with a single WAITCNT with an 80MHz system clock. You simply can't fit enough bits in a 32-bit word to do that (the system clock wraps around at 32-bits). You can do two 30 second delays in succession like:
    waitcnt(clkfreq*30 + cnt)
    edited 2007-08-07 17:17
    Mike, I can get 59 or 61 seconds with three waitcnt statements.· Right now I'm incrementing one of the waitcnt statements in steps of 10_000_000 to see if I can bounce around the 60 second wait.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-07 17:21
    Sid,
    I don't understand why you can't get a 60 second wait with two WAITCNT statements as I've shown it.
    Could you post exactly what you're doing? One of us may be able to see what you're doing wrong.
    edited 2007-08-07 18:58
    Mike, I can get·61 but I can't get exactly 60.· I'm time stamping each EEPROM store and the clock shows minus one second with each read or plus one second.· This sequence gives a 1-second increase in each time stamp.· Wait = .5 secs
    ··· waitcnt(wait*28 + cnt)
    ··· waitcnt(wait*32 + cnt)
    ··· waitcnt(wait*27 + cnt)
    ··· waitcnt((wait*26 + 30_000_000) + cnt)
    The above comes to 56.5 seconds + .375 seconds.· The rest of the time is overhead from the Propeller and the attached BS2E.
    If I change 30_000_000 to 25_000_000 the time stamp show a 1-second decrease with each entry.
    Sid
    Don't have VGA?
    Newzed@aol.com
    Post Edited (Newzed) : 8/7/2007 7:02:57 PM GMT
    edited 2007-08-07 19:17
    The WAITs you give are certainly exact. I think there is something hidden within the 3.125 seconds left... A sync of some kind...
    edited 2007-08-07 20:02
    Sid,
    What you describe doesn't make sense. I'm assuming that wait == 40_000_000 and that you're using an 80MHz system clock.
    There must be something about the stuff that you're not showing us that accounts for this. Also, changing the 30_000_000 to 25_000_000 should not result in a change of 1 second. Don't forget that the overhead between the Propeller and the BS2E may account for the differences you're seeing. I suspect that the delay time is indeed correct and how you're measuring it is not.
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-08-07 20:14
    What happens to this routine's behavior if you take out the multiplications? Then you are down to base overhead of 381 cycles per waitcnt(offset + cnt).
    edited 2007-08-07 20:26
    ··· waitcnt((wait*27) + cnt)
    and the time increased 1 second each reading.· I changed the last line to read:
    and the time decreased 1 second with each reading.· That's a change of 10_000_000 = .125 seconds
    wait = 40_000_000 = .5 seconds
    There were absolutely no changes to the program except the waitcnt changes.
    I guess I'll just accept the 1 second increase and quit worrying about it.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-07 20:35
    Sid,
    You've done this before ... come up with some kind of odd problem that doesn't make any sense, shown only part of the context, fiddled around a little, then given up.
    You have a complex system here, cobbled together from bits and pieces ... this Propeller cog talking to that Propeller cog talking to a BS2e talking to a DS1302 clock chip. No wonder odd things happen.
    Usually, when you have odd behavior without an explanation and understanding, it'll rear up again later and bite you ... or maybe it won't.
    I don't think this has much to do with the waitcnt's. Add figuring this out to your probably long list of todo items. Stay cool!
    Mike, I deleted all the waitcnt statements and the displayed time increased 2 seconds with each reading.· On the tenth reading it increased 3 seconds, then back to 2 seconds until the next tenth reading, and so on.
    Sid
    Don't have VGA?
    Newzed@aol.com
  • ericballericball Posts: 774
    edited 2007-08-07 20:39
    You should be able to do the following:
    CNT0 := CNT
    WAITCNT( WAIT30s + CNT0 )
    WAITCNT( WAIT30S * 2 + CNT0 )
    That way you're always working from a fixed base time, not the time the WAITCNT executes.· That also makes the time required for the multiplication etc irrelevant (for sufficiently long delays).
    edited 2007-08-07 20:47
    Mike, you said:
    "You've done this before ... come up with some kind of odd problem that doesn't make any sense, shown only part of the context, fiddled around a little, then given up."
    I NEVER give up.· I said I had, but I didn't really mean it.· I have solved every problem I ever had - sometimes it took me days but I eventually got there.· So will it be with this one - sooner or later I will find the reason for the strange results I am getting.
    I really appreciate your help, past and future.· When I stumble across the explanation for this problem, I'll let you know.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-07 20:51
    Eric, what is wait30s?
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-07 23:38
    wait30s might be the time required to wait for 30 seconds ?
    Post Edited (Graham Stabler) : 8/8/2007 8:18:22 AM GMT
    edited 2007-08-08 03:09
    WAIT30s is a variable or constant which is the number of system clock ticks in 30 seconds (i.e. 2,400,000,000 for an 80MHz clock).· CNT0 is a long variable.
    edited 2007-08-08 11:58
    Eric, I tried the cnt0 thing - with one waitcnt statement it gives the same as ctn.· Wjen I tried it with two waitcnt statements I got about 60 secs· total with cnt, but only about 34 secs with cnt0.· I debugged the dec values of the two cnt's.· If the first was positive, the second was negative.· If the first was negative, the second was positive.· I really don't know how cnt is derived so I can not explain why one or the other is negative.· I'm just reporting what I am seeing.· You would think that when cnt exceeds 32 bits it would just roll over and start again.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-08 12:42
    Mike, I wrote:
    ··· waitcnt((wait*51 + 30_000_000) + cnt)
    ··· waitcnt((wait*59 + 7_000_000) + cnt)
    Over a period of 30 minutes, the display gained 3 seconds,·which equals ·.1 seconds per minute or 6 seconds per hour.· I don't think I'm going to get much closer than that.
    Sid···
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-08 13:05
    Sid,
    CNT is just a 32 bit register that is incremented by the system clock. It does indeed roll over and start again. When the high order bit is a one, it will test as negative. When the high order bit is zero, it will test as positive. It's used as an unsigned 32 bit number. The WAITCNT instruction logic tests for equality with the destination field. The Spin method just adds a little overhead (microseconds) to the instruction itself.
    With a 5MHz crystal, that's roughly 8KHz high which is a lot, but could be affected by crystal loading (with capacitance).
    1) What board are you using for the Propeller and for the clock?
    2) What's the XTALn setting in your code?
    3) It would be interesting for you to borrow a frequency counter to check both oscillators.
    edited 2007-08-08 13:23
    Mike, I am using a Proto Board.· It comes with a 5mHz crystal installed.· Here is my CON bloack statement:
    · _clkmode = xtal1 + pll16x
    · _xinfreq = 5_000_000
    The DS1302 is a special module I built for the Proto Board and plugs into Prop Pins 2, 3 and 4 via a header I installed.
    A frequency counter would be nice but I don't know of any one that has one.· In fact, I haven't even been able to find an electronics/Stamp/Proppeller aficionado in the Port Richey area.· So I'll just have to stumble along on my own.
    I re-ran the test I reported in my last post.· Now the display is losing 4 secs every 10 minutes.· Must be due to this room warming up a bit.· Going to run it several more times with the same waitcnt parameters and see what happens.· The temperature in here has increased 2 or 3 degrees since I ran the first test this morning.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-08 13:37
    Have you checked your DS1302 against some other time standard? How does it compare over several days with WWV?
    edited 2007-08-08 14:57
    Mike, with:
    ··· waitcnt((wait*59 + 7_000_000)+ cnt)
    i was losing about 400ms every minute.··I increased the wait 400ms to:
    ·· waitcnt((wait*59 + 39_000_000)+ cnt)
    and I still am losing about 400ms per minute.· Before I go any further, why did the 400ms increase not·increase the display?
    I thought about the 1302 inaccuracy.· If it was losing X ms every minute, the loss should be consistent and I should be able to compensate for it.· I'm not terribly concerned about how accurate the DS1302 is right now.· I'm more interested in getting a delay of 60 seconds.· I can get close to it but I can't hit it right on the button.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-08 15:14
    Sid,
    How do you know what 60 seconds is? I keep coming back to this and your postings keep ignoring it.
    If you have:
    VAR long halfMinute
    and:
    halfMinute := clkfreq * 30
    then:
    waitcnt(halfMinute+cnt)
    will give you a 60 second delay (+ maybe 300us overhead) if your system clock is 80MHz.
    If you're seeing something else, it's not the waitcnt statements.
    edited 2007-08-08 15:46
    Mike, I am not ignoring the 1302 - I don't ignore anything you say.· I just ran a test for hour.· I had previously set the clock to 10:35:00 per my WWV clock.· At the end of the hour, as near as I could tell, the displayed time matched the WWV clock time, at least within a fraction of a second.· However, over the time of one hour, the display lost about 42 seconds
    I'm·going to change the wait count to:
    waitcnt(clockfreq*30 + cnt)
    Each reading should be 30 seconds plus overhead.· I'll let you know what I get.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-08 18:30
    Mike, I wrote:
    waitcnt(clkfreq*30 + cnt0 and the wait was 4 secs too long each read.
    So then I wrote:
    waitcnt(clkfreq*26 + cnt) and the wait was 4 secs too short over 10 mins, i.e., 44:15 to 54:11
    I debugged clkfreq and screen said 80_000_000. Don’t know if that was calculated or measured.
    Then I wrote:
    waitcnt(wait*52 + cnt) – ditto········· ·‘wait = 40_000_000
    Changed wait in the CON block to 20_000_000 and wrote:
    waitcnt(wait*104 + cnt) – ditto
    Then I increased the wait .25 secs and wrote:
    waitcnt(wait*105 + cnt) - ditto – 11:40 to 21:36
    Then I increased the wait another .25 secs – total increase .5 secs - and wrote
    waitcnt(wait*106 + cnt) – ditto
    waitcnt(clkfreq*30 + cnt) – wait was 4 secs too short over 10 mins, i.e., 58:33 to 08:29
    waitcnt(clkfreq*31 + cnt) – wait still 4 secs short over 10 mins – 14:21 to 24:17 – even after a 1 sec increase. How do you explain that?
    I’m emotionally exhausted – think I’ll take a little nap.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-09 13:28
    Good morning, Mike
    Took a break from my waitcnt problems and modified my program so that everything that appears on my VGA also appears on Hyperterminal.· Now I can display the data stored in EEPROM and capture it to an Excel file.· More important, I can now use the Proto Board on the bench where I have no spare VGA - I just use Hyper as a substitute.
    Back to waitcnt.· I wrote:· (wait = 20_000_000 or .25 secs)
    ··· waitcnt(wait*109 + cnt)······· '27.25 secs
    ··· waitcnt(clkfreq*29 + cnt)····· '29 secs
    In 10 minutes the display lost 4 secs - 07:38:23 to 07:48:19.
    I·added to the above two commands:
    ··· waitcnt(wait + cnt)···· 'that's .25 secs
    Now the display gains 17 secs in 10 mins - 07:41:33 to 07:51:50.
    I know I'm trying your patience, but can you explain why the display gains a total of 21 - (17 + 4) - secs when I add .25 secs to the wait.· This has nothing to do with the accuracy of the 1302 - so maybe it gains or loses a second every minute.· At least it is consistent and has no bearing on the waitcnt sequence.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-08-09 14:33
    Sid,
    You're only showing a few lines from a complex program. There's interaction with a serial port. There's interaction with a Stamp with a timer on it. All of these can introduce some granularity and delays. I can't give you any idea of where the time is going because I neither have the rest of your program nor do I want it. The problem is not in the waitcnt!! If there was something wrong with this, none of the time-dependent stuff would work ... particularly serial I/O. If it were me, I'd just put in the two 30 second long waits and start looking for other causes for missing time. Don't forget that the process of measuring time and communicating time takes time.
