Spin 24 Module
There are three unused pins on the Spin 24-pin module, 1,2,3.
Is it possilbe to wire these to three unused i/o pins on the popeller chip?
cheers,
rich
cheers,
rich
You'll see that pin 3 is already connected to a Propeller pin (with a series resistor). Pin 1 is intended as a serial output and pin 2 is intended as a serial input (with echo to the output).
