Reading RTS pin with BS2
Suman
I am trying to read the pulse on the RTS pin of the RS 232 using Basic stamp.
I'm planning to connect the RTS pin of the serial port to one of my basic stamp pin (that pin being an input pin, set by DIRS) and then reading the pulse (high or low) with INS.
I am not sure if INS command can be used to check the level (or status) of an input pin of BS2.
Can anybody help me...
Please go through the "What's a Microcontroller?" tutorial. It discusses the use of input and output pins and gives programming examples. It can be downloaded from the Parallax website under the Stamps in Class menu item.
If you're trying to use RS-232 flow control, that's not the way to do it. Take Mike's suggestion, or at least consult the PBASIC Stamp Reference Manual, or the PBASIC Stamp Help file for details on how to use SERIN/SEROUT properly.
Bruce Bates
