is there a simple way to get composite sync from the VGA driver?
I have this nice little 320x240 vga lcd, the only part of the equation I am missing at the moment is the composite sync that it needs
anyone know how to get it from the VGA driver?
Parallax Forums - If you're ready to learn, we're ready to help.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
Franz
http://www.mp3car.com/vbulletin/lcd-display/69538-sharp-casio-gamecube-display.html
I got it to show some info using vga text, but nothing more than distorted video, any hints for adjusting the front porch back porch etc??
Post Edited (CJ) : 8/6/2007 6:02:38 PM GMT
this is a Sharp 6 Inch. Should be easy to get it up and running at the Propeller VGA Port.
You have to take care about Pin7.
See my Thread for more infos:
http://forums.parallax.com/forums/default.aspx?f=25&m=206606
But you have to do some work for the right timing and Param-settings !!!!!
A scop connected to H-Sync helps by testing it out (15- 16 KHZ or so).
br
Franz
i can see that your composite sync signal is connected to pin 7.
Just take a resistor valued to 1k and a Diode (1N4148 or so).
Connect the resistor to Pin7 and the open end gives you VSync to the Propeller.
Connect the Diode to Pin7 (anode Pin7) and Kathode gives you HSync to the Propeller.
That's all, the rest is your work (optimize timing etc....).
br
Franz
Post Edited (CJ) : 8/6/2007 10:22:51 PM GMT
very nice done
I just discovered that in this sits a high quality Sharp TFT Display with 480 x 234 pix:
http://cgi.ebay.de/Playstation2-Joytech-7-TFT-Monitor-Reisepaket-NEU_W0QQitemZ110153851890QQihZ001QQcategoryZ14259QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Its exactly the same (LQ070) i am playing with at my propeller VGA port.
Franz
I could not get the correct timings for it, which almost drove me insane. I settled on using a 17 inch computer monitor instead since it didn't seem worth the trouble.
be back in about 20
PR / HF = PPL
then I padded the horizontal front porch, back porch, and sync to fill the line
HFP + HBP + HSYNC = PPL
for the Verticals, I just experimented, using Ctrl+F10 to try various settings
now that I am writing this, I think I may have been lucky, didn't know what almost all of these settings meant before today
