#27976 #27977 Serial_LCD_Demo.sxb slimming causes failure
John Kauffman
The sample code provided for part #27976 #27977 Serial LCD (Serial_LCD_Demo.sxb) works like a charm. Line one displays a message, line two displays a message with animation and then it all flashes.
Now·I'd like to get a leaner version, similar to the "template" offered for other proudcts (viz. DS1302). In this case, just the line one display.
Deleting the block of code for flashing works fine (Serial_LCD_Demo-NoFlash.sxb).
But when I delete the animation code & run, I get nothing on the screen, not even the first line (Serial_LCD_Demo-NoFlash-NoANimation.sxb).
Any suggestions? All three files attached below.
Thanks.
Thanks.
· It is because you are clearing the LCD as soon as you display the string.
· Right after you do the LCD_STR command, you loop back and clear the screen.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
