Strange IR detector behavior, using PEK bot code
Ok the program I am running is quite simple:
'print reading (1 or 0)
Here is the object method, which I'm assuming works since its from the PEK bot code:
The code loads and runs fine, but the results I am getting are strange. I only see "0"s in the terminal window no matter how I try to reflect/cover the IR led. However, if I unplug and remove the IR led altogether, I get all "1"s. I then substituted a regular LED for the IR one and I still get the "1"s. When I put the IR led back, I get "0"s. It's like the IR led affects the detector's output, but not in the intended way (using reflected IR light). What's going on?
Alternately, I found something strange with the PEK bot's schematic. It shows the IR receiver wired like this:
but a diagram I have (I'm pretty sure its from the boe-bot book) shows the lower 2 pin's reversed. A look at the PNA4602's datasheet also confirms the boe-bot wiring, which is the one I used. Could this have something to do with it?
I'm new to the propeller!
'' File: IRDetectTest.spin VAR CON _xinfreq = 5_000_000 ' 5 MHz external crystal _clkmode = xtal1 + pll16x ' 5 MHz crystal multiplied → 80 MHz OBJ term : "PC_Interface" IRDetect: "Ir Detector" PUB mainMethod term.start(31,30) 'init terminal and IR detect objects term.str(string("starting up")) IRDetect.init(26,27) repeat term.dec(IRDetect.object)
PUB object :state | pin, freq, dur {{IR object detection. Returns state - 0 indicates that an object was detected. 1 indicates no object}} pin := ledPin freq := 38000 sw.start(@pin) dur := (38000 / 400) waitcnt(cnt + clkfreq/500) state := ina[noparse][[/noparse]recPin] sw.stop
+5V   │ ┌┐ └──┤│ P14 ──────────┤│‣ 10 kΩ ┌──┤│ │ └┘  PNA4602 Vss
