PING sensor Waterproofing?
Vern Graner
I am in the process of creating a display for a museum that will incorporate a number of PING)) sensors in locations where patrons can reach and interact with them.
Each sensor will be oriented to face upwards allowing people to "hover" their hand above the sensor to operate the exhibit. I'm worried about people intentionally or unintentionally getting liquid, dirt etc into the sensor. I'd like to "waterproof" the sensor also to help facilitate cleaning.
I assume I would have to use an acoustically transparent covering of some sort, but before I started experimenting with all kinds of things I thought I'd ask to see if anyone has already solved this particular problem. [noparse]:)[/noparse]
Vern
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Futurlec has individual waterproof ultrasonic sensors for sale in their sensors section. You would have to remove and replace the present sensors on the PING))) with the waterproof ones.
You might want to consider using high power IR diodes and an IR sensor. Using high power IR diodes gives a good return signal to the IR detector even when the reflective surface is dark.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
http://forums.parallax.com/showthread.php?p=611967
You might also consider a 45 degree reflector so that the sensors could be facing horizontal.
Tracy Allen
www.emesystems.com
