LCD Appmod pinout?
I'm trying to use this (www.parallax.com/detail.asp?product_id=29121) on a board without the appmod header and I need to know which pins to connect. Looking at the code samples, it appears that only pins 1-3 are used:
However, looking more closely on the LCD PCB, there are lines going out from pins 1-7. That said, the sample program for mini sumo has pin 4 used for an IR LED. So am I correct in assuming I only need to connect pins 1-3, and of course, Vdd and gnd?
I'm new to the propeller!
E PIN 1 ' LCD Enable (1 = enabled) RW PIN 2 ' Read/Write\ RS PIN 3 ' Reg Select (1 = char)
The AppMod LCD is parallel, not serial, you'll need to use D4-D7, too.
[u]AppMod Pin #[/u] [u]Descr.[/u] [u]I/O[/u] 1,2 GND -- [color=red] 3 P0[/color] [color=red] 4 E P1[/color] [color=red] 5 RW P2[/color] [color=red] 6 RS P3[/color] [color=red] 7 D4 P4[/color] [color=red] 8 D5 P5[/color] [color=red] 9 D6 P6[/color] [color=red] 10 D7 P7[/color] 19 Vdd --Post Edited (PJ Allen) : 8/5/2007 6:43:12 PM GMT
