Propeller Plug - connection different
I have made my own protoboard and wired the connector for the Prop. Plug as per the drawings/pics in the documentation.
However, I have just received my Plug, and find that the connections are in a different order, which means that I will need to redo my board in that area.
That's OK, but obviously this particular Plug won't be compatible with the demo board if used.
Has anyone else noticed this?
kenmac
Perth, Western Australia
Time Zone = GMT + 8
kenmac
Time Zone = GMT + 8
Can I connect the Propeller directly to a PC comm port with current limit resistors?
Propeller TX to PC Rx ( Pin 2 on 9pin D Connector )
Propeller RX to PC TX ( Pin 3 )
Propeller Res to DTR ( Pin 4 )
Gnd to Gnd ( Pin 5 )
Thanks.
www.fd.com.my
www.mercedes.com.my
It should have been #32201, which is the one shown in the documents/pics.
I wasn't aware that there was more than one version of the Plug - my mistake.
kenmac
Time Zone = GMT + 8
Even more important is the fact that RCV and XMT have to be inverted, as this is assumed by the Propeller IDE and by the bootstrap loader. When later using program controlled serial I/O this can be cared for by software of course.
Second, the reset-logic is a little bit tricky
Parallax has published at least 2 different versions of transistor based circuits; I found a third useful one in the current robotics issue of the ELEKTOR journal.
Ken the unit you have will work.
The Protoboard from Parallax #32212 will take all three suitable programmers being
#28024 USB ser dev tool
#32201 Prop Plug
#32200 Prop Clip
cheers·· Ronald Nollet·· Parallax Australia disty
I will fix the pinout on design # 2 hehe
Russell.
