I need a robust servo
I think I need a servo that is more robust than the standard 900-00005.· I want to use my servo to drive the pointer for a sort of gauge or meter to monitor changes in resistance.· My pointer needs to be about 12 inches long and 1/2" wide and will be made of sheet aluminum or plastic.· So is the 900-00005 robust enough to handle that, or should I get a heftier one?· If the latter, what would be a part number that is Basic Stamp compatible?· Thanks
- Stephen
You need to take into account the inertia when changing the velocity of a large object (balanced or not). Make sure you rev up and rev down the movement of your servo accordingly or you'll end up using a lot of power and/or grinding your servo's gears to dust (especially the ones with the plastic gears) and/or frying the servo motor in a short time.
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
| "Wait...if that was a compliment, why is my fist of death tingling?"
| - Alice from Dilbert
