could this situation kill my chip
referring to all cmos micros:
when a pin is switched to an input, i assume a tristate buffer connecting the pin to an output d-latch is switched to high impedance, so
the contents of the output reg cannot conflict with incoming signals.
this is really a general question regarding electronics.
what would happen if 3.3v were applied to a pin that WAS in output mode and the latch contained a 0.(i am unfamiliar with the impedance characteristics of cmos) would something short and burn out, or would there just be a signal of 1.65v(in the middle) or something?
The Propeller is the best micro!
srry if im sound a little unprofessional sometimes, im 15.
Post Edited (Mr Crowley) : 8/3/2007 7:37:40 AM GMT
Post Edited (Mike Green) : 8/3/2007 4:29:39 PM GMT
also, on startup, what are the default pin directions?
For an example, the Stamp HomeWork Board has 220 ohm resistors in series with all the I/O pins to protect against this sort of accident. It's a risk reduction thing. The more sure you are of your circuit and your programming skills and care, the more you may be willing to do without the protective resistor. In some circumstances, the series resistor can interfere with what you're trying to do with the I/O pin.
i think im gonna go write a guide for getting started with the propeller.
Paul Baker
I bet Prop V2 will solve world hunger and establish world peace. I just hope they get it finished on time. No pressure on the design team.
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
| "Wait...if that was a compliment, why is my fist of death tingling?"
| - Alice from Dilbert
