Protoboard servo power not working (protoboard exploded?-fixed!)
see post #4 for new problem
I just had it working and then it stopped. I have the jumper hooked across the middle and bottom (Vin) pin. Now I only measure about .29V or so between the top and middle pin on the servo headers. I do however measure Vin correctly at the jumper point. When I had it working, the servo headers were correctly reading the battery voltage (Vin). What could have happened? It seems to me that there is something wrong with the capacitor and inductor (?). Right now I am considering removing those 2 components and directly wiring the jumper to one of the four servo headers, would this work? Any advice on preventing/fixing this problem would be nice too. Thanks.
Edit: I just measured the voltage across the inductor and it is 8.00. Vin (battery voltage) is about 8.28. That leaves roughly ~.29V on the servo headers. Is this normal?
I'm new to the propeller!
Post Edited (bulkhead) : 8/4/2007 5:32:15 AM GMT
You may also not need it, just bridge the inductor with a short piece of wire. It is with this as it is with the decoupling capacitors, it may run well without it.
Avoid this happening again? Don't overload the circuit. May be a good idea to put a fuse there. Although fuses usually cost more than petite inductors...
I was only running 2 motors through the 4 servo headers, drawing 2 amps at most (otherwise, my H-bridges would go). I guess I'll just add the jumper whenever I use these motors or high torque servos.
Is there a diagram that shows where all of the connections are physically on the protoboard? I'm trying to trace the path and figure out what happened. It seems like the motors current need exceeded the capacity of the board. I checked the voltage regulators with a multimeter and they are working fine. At the jumper point where the servo voltage jumper goes (to select from Vin or 5V), I measure correctly Vin and 5V. I currently have the jumper on Vin. The propeller also programs fine, but there's no voltage at the servo headers. Any help would be appreciated.
Post Edited (bulkhead) : 8/4/2007 3:20:49 AM GMT
That's why fuses were invented!
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Lesson learned: Test connections not just before, but AFTER mounting boards, especially onto a grounded frame!
Alternate lesson learned: Don't ground the board onto the frame? This seems like the easier and most logical solution; just don't have a large conductive structure hanging around to cause a short.
Post Edited (bulkhead) : 8/4/2007 3:21:44 AM GMT
