Pollin on the BS2p40
Hello,
Does anyone know if there is a way to seperate the auxio and main io when using the pollin commands?
I need to monitor a pin in the auxio.· It seems that it monitors the same #pin from both the auxio and mainio.· I realize I can check the bit status and decide where to go from there.· But I would like to avoid going into the routine given by the pollrun command unless the·actaul auxio pin is triggered.
Aaron
Aaron
Tracy Allen
www.emesystems.com
