problems with mouse(x-y-z) values
Hello,
i have some problems with the xyz-mouse-values.
In the first example only mousez shows the correct value.
gr.textmode(2, 1, 6, %1000)
gr.text(-71,72, Num.Dec(mousex))··
gr.text(-71,56, Num.Dec(mousey))
gr.text(-71,40, Num.Dec(mousez))
In this example mousey is ok.
In this example all values are correct.
Why do i have to use gr.textmode for the mouse-values all the time???
thank's and best regards
Franz
Franz
'' address of zero-terminated string (it may be necessary to call .finish
'' immediately afterwards to prevent subsequent code from clobbering the
'' string as it is being drawn
It looks like the subsequent calls to textmode just make sure it gets chance to be written.
Graham
many thanks, you helped me out by this one.
When i use gr.finish it works and it saves me 4 longs.
gr.finish
gr.finish
thanks
Franz
