OSC1 device setting for SX48
Boxcar
I've been having an issue with loading of the oscillator1 line on SX48s. I am running several SX48s off the output of one clock chip (at 50mhz) and have selected OSCHS3 as the oscillator type in the DEVICE setting. The clock signal level drops significantly when multiple SX48s are connected. Would changing this setting to HS1 or HS2 reduce the loading on the OSC1 pin? Does anyone know what the internal configuration of the oscillator is for the different clock settings?
Try the DEVICE DRIVEOFF directive to see if this makes a difference. You may also try the DEVICE FEEDBACKOFF directive to de-activate the internal feedback resistor.
Greetings from Germany,
G
