Parallax 912MHz Transreceivers
Hi all,
I finally got my pair of Parallax 912MHz transreceivers working and I would like to say that it was one of the easiest projects that I have put together in a while.
The transreceivers have very good range and work great even when one transreceiver·is a floor above the other.
I am presently using one transreceiver to transmit the digitized (BS2e/ADC0834) x and y values of a pair of two axis joysticks and the on/off state of six switches. The other transreceiver receives the transmitted data stream,which a BS2e processes and then hands·off over a serial connection to a mini-Bot Board, that controls my Lynxmotion 4WD1 Rover.
The transreceivers/BS2es are taking the place of a PS2 wireless controller and receiver that normally control 4WD1 Rover. This way I can have two way communication with the Rover.
My control system is a modified version of the "Follow Me" Lynxmotion 4WD1 Rover thermal tracker that appeared in the July issue of Robot. The difference being that I can take manual control of the 4WD1 Rover over the wireless link and well as hand off to the TSA sensor for automatic·steering and speed.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
TCIII
