analog input
What is the easiest way to interface analog signal w/ bs2?
is it the RCTIME method?
Lenny Bogdanov
Systems Concept Center
Lenny Bogdanov
Dave
Dave Andreae
Parallax Tech Support·
Tracy Allen
www.emesystems.com
Lenny Bogdanov
I'm currently documenting a TSL1401 daughterboard that I've designed for the MoBoStamp-pe. Do you really need 256 pixels? Or would 128 be enough? If the latter, you could save an enormous amount of effort by waiting a bit. Attached is a photo of the MB/DB combination. Also attached is a screenshot from the PC-hosted real-time monitor program.
Can you tell me more about your app?
(essentially approximate edge detection on a black wedge).
Im also thinkign about just going to somethign like the tsl3301 (or whatever model) the only taos opto linear array with a built in ADC.
I may also just purchase some external ADC...
Time is a real priority for me
Lenny Bogdanov
Post Edited (lenny1337) : 8/1/2007 5:00:29 AM GMT
What is your timeframe exactly? Given that the BASIC Stamp won't be able to contain all 128 8-bit pixel values, are you able to do your analysis on the fly, or are you planning to have a connected PC do that for you after receiving the pixel values?
Lenny Bogdanov
Altenatively, if you need something right now, TAOS's TSL3301EVM may do the trick for you. It's not programmable and has only 102 pixels, but you can send it commands and read pixel values from it using the documented protocol from your own PC host program. The TSL3301EVM uses the same lens as the TSL1401-DB, but it also comes with a SELFOC lens for 1:1 contact imaging.
Thank you very much for the offer - currently, i've managed to get this thing working with a TLC0831 ADC and i'm now getting the appropriate values that i'm looking for. If this changes and I find myself in need of a better interface (and UC) I'll let you know and we can work something out.
BTW do you find that "white" LEDs are the most effective for lighting? also how important is having a lens?
Thanks for your time.
Lenny Bogdanov
I'm glad you got something going so quickly!
The TSL1401/1402 has a peak response in the red region of the spectrum, so I would use ultrabright red LEDs with it.
A lens is critical if you're doing imaging and not just trying to detect ambient light levels. However, it is possible to project a shadow directly onto the chip without a lens. This might be the case if you're trying to do precision edge location over an area smaller than the 8mm or 16mm sensor length. The edge won't be in focus, unless the backlight source is a pinhole or well-collimated beam, but this can work to your advantage. By analyzing the Gaussian intensity distribution across the shadow, you can obtain a position that's precise to a fraction of one pixel width.
Since you're dealing with reflected light — presumably from a diffuse surface — I can't see how you'd be able to do anything useful without a good lens.
Also, if you're reading the A/D converter with a BASIC Stamp, be sure to read out all the pixels as fast as you can. Otherwise, you'll be confronted with "pixel droop", which occurs when the capacitors that hold each pixel's charge start to self-drain. This will be particularly noticable in the last pixels read out, since they've had to sit the longest. The TSL1401/1402 datasheet specifies a minimum readout clockspeed of 5KHz, but you can probably get by with 1KHz or even slightly less.
Post Edited (Phil Pilgrim (PhiPi)) : 8/2/2007 12:52:34 AM GMT
My name is James T. Norman and I am interested in your tsl1401 mobo-pe daughter board, how can I acquire some? do you have the spec's available yet? and how much are they? appreciate your time, look forward to your response.
thank you,
BIOTRAQ Inc.
903-871-3127
James T. Norman /ceo-cto
jamesnorman@luxorsensoptics.com
