I'm about to spend over $300 on a Vantec speed controller which I will use with 24 volt electric wheelchair motors. I'm wondering if anyone knows of a better alternative. The HB25s would be my first choice if only they would work with 24 volts.
They are distributed in the US by Acroname: www.acroname.com/robotics/parts/R133-MD03.html
At $125 per driver, I'm not sure if that's substantially cheaper than the Vantec controller, but having I2C is really, really nice if you are interfacing to a micro such as the Stamp, SX, Prop, etc.
I've always been very satisfied with the motor controllers I've purchased from the link below and they are directly controllable from a PBASIC Stamp or any other microcontroller: http://members.tripod.com/~divelec/index.html
Thanks for the tips, I think the Devantech doesn't quite have the amps I'm looking for, I wanted at least 25. I'm going to look into the Diverse controller some more, that's one that I hadn't come across before.
www.robot-electronics.co.uk/htm/md03tech.htm
Bruce Bates
Thanks!
